Hello
I was hoping someone may be able to advise me. I have made a live edge table and have some steel legs to attach. Does anyone know if I can directly screw these onto the wood ? Or would it require a frame ? I’ve attached some photos and be grateful for any advice. The wood is 180cm X 50cm X 4cm. Legs are around 102cmx36x 5cm . Thanks !
Hi @emilydg
Nice bit of timber you have there
If you wanted to be extra carfull to not split the wood you will need to mark with a texta the timber from underneath where the leg mounting holes will go.
Then pre drill a smaller pilot hole hole (1/2 diameter of screw as a guide) only drill 20mm deep or less for a 20mm screw.
I would only use a 20mm wood screws
This will gently mount the wood to the legs.
Hello @emilydg
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about attaching legs to your table.
That's excellent advice coming from @Jewelleryrescue. Drilling pilot holes will prevent the wood from splitting and makes it easier to mount the screws on the timber benchtop. If your worried about the length of the screw, I suggest placing the screw you are about to use on the side profile of the tabletop. This will give you an indication of how deep the screw will penetrate into the timber panel.
I also suggest positioning the legs on the tabletop to give you an idea of where they will permanently stay. I recommend doing a test fit to make sure that the legs are not too close to each other or too far apart. Once you've decided where to put them, make sure to mark the screw holes with a pencil. Remember not to drill too deep or it will come out the other side.
Please make sure to wear personal protection such as gloves and goggles when working on your project.
Hi @emilydg,
Just checking in to see how your table build is progressing. I trust you found the advice received helpful. Please don't hesitate to post again if you need additional help. We'd also love to see the completed table when you finish.
Thanks,
Hi everyone
thank you so much for all your helpful suggestions ! It’s very much appreciated and I took them on board! Here is the final table
Hello @emilydg
Thank you so much for sharing that update on your live edge table project. It looks fantastic, the gold colour of the legs really enhances the finish of the panel.
We look forward to seeing your next project.
