How to attach a roller blind to a skylight  (including hold down capability)
ccyounger
I have an old velux skylight, which I can access easily, and I need to attach some sort of blind to it.
(yes it needs a clean)
My preference is a cheap roller blind.
The window is on a slant, so a roller blind would need some sort of clips at the bottom, to hold the bottom of the blind against the window (and not have it simply drop vertically)
I'm not sure if this sure if this fixture exists, or if there is a better approach to take?
Thank you
Re: How to attach a roller blind to a skylight  (including hold down capability)
Hello @ccyounger
Thanks for sharing your question about attaching a roller blind to your skylight. Your Velux Skylight might still be compatible with the roller blind sets that Velux produces. Somewhere along the timber frame is a plate or tag that has the model number of your Skylight. If you can provide that model number, I'll be able to ask Velux if they have a compatible roller blind. Can you also please provide the dimensions of the Skylight?
In regards to installing a regular roller blind, I'm afraid there is no ready-made hook to hold the blind in a diagonal position. I suggest having a quick look at this discussion - Options for installing a skylight blind? by @KC6288.
ccyounger
Hi Eric,
Thanks for the quick reply.
Below is a photo of the Velux plate, it's a bit hard to read and says:
GGL-1    1025 0 04 Ø
I think the window is about 25 years old.
It would be a great help if you could find out if Velux have a corresponding newer frame code I can use.
Thanks again
Hello @ccyounger
Thanks for finding that tag so quickly. The good news is that Velux has compatible blinds for your skylight. The two models are the DKLM04 - Blockout Blind and the FHCM04 - Honeycombed Blind. If you need a control stick the model number is ZXT 200.
Depending on your budget you can get a quote for a motorized version and the control switch for the wall. Please keep in mind that you will need a licensed electrician to install the unit.
I suggest going to your nearest store and asking a helpful team member at the special orders desk for a quote on the blind. Please make sure to provide the model number of your skylight, the model number of the type of blind that you want and the number of the control stick if you need it. As a safety measure please include the measurement of your skylight. If you are interested in the motorized version make sure to ask the team member to make a motorized quote as well.
ccyounger
Hi Eric,
Thanks so much for this - great to know there are Velux options.
One last question - would I be right in thinking that the 'M04' part of the model number is the part that refers to the frame-size?
With the 'FHC' part identifying Blockout and the 'DHC' identifying honeycomb?
Chris
Hi @ccyounger
I'm not really sure about the definition of the codes as the technical person I was speaking to did not explain their meaning. The M04 could be referring to model number 4. But what I do know is that these codes are specifically meant for your Velux blind GGL-1.
Here is a link to the Velux Blinds: Velux Blind Models
ccyounger
thank you Eric, this has been a really helpful experience.
