How can I mount a stick vacuum wall charger on tiles in a rental?
paveln
I tried using Gorilla Tape, but there's not enough contact surface on the fact of the wall mount for it to stick.
I'm imagining the solution would be something like suction cups with a screw/nut, but would love to hear your ideas.
Re: How can I mount a stick vacuum wall charger on tiles (renting)?
Hello @paveln
Thanks for sharing your question about mounting your stick vac to your tiled wall. I suggest using something stronger like Scotch-Mount Extreme Double-Sided Mounting Tape 2.5cm x 1.5m. Please note that this is very strong mounting tape and could end up damaging your stick vac holder when pulled away from the wall. Another option is to build your own stick vac stand. I suggest having a look at this guide - How to build a stick vac stand. It's an easy to build stand for your stick vac so you won't have to drill into your walls or tiles. The best part is the stand can be placed anywhere.
My best advice is to wipe the tile and stick vac holder with isopropyl alcohol.
