How and what insecticide to use for inside and outside of the house?
mmd22
Building a Reputation
Hello All
I am wondering is there any insecticide I could use for most insect inside and outside including roses , Grasses and vegetables Garden .
Specially for cockroaches, ants ,red back spider ,slugs, lady bug and  caterpillars.
Thank you all .
Re: How and what insecticide to use for inside and outside of the house ?
Hi @mmd22,
There isn’t a single insecticide that can effectively manage all the pests you’ve mentioned while being safe for indoor, outdoor, and plant use. However, there are targeted solutions you can use. For cockroaches, ants, and redback spiders, PestXpert 2L Indoor/Outdoor Multi-Insect Contact and Residual Barrier Spray is an excellent choice. It works well on hard surfaces both inside and outside your home but is unsuitable for use on plants. For caterpillars in your vegetable garden, I recommend using Yates 200ml Success Ultra Insect Control.
To deal with slugs, Eco-Organic Garden 600g Eco-Shield Organic Snail & Slug Killer is highly effective and can protect your vegetables. Be sure to place it around affected areas.
Lastly, ladybugs are harmless and beneficial to your garden as they help control pests like aphids, so there’s no need to eliminate them.
mmd22
Thank you so much again @MitchellMc  for very help information .
Could I please ask what do you think about this product for indoor and outdoor pest control as I do not find  much information.
Hi @mmd22,
The Hovex 1L Ultra Lo-Odour Termite Concentrate is suitable for insect control around your home and it specialises in controlling termites. If you have a termite problem, this could be a good solution.
The Coopex is another option. It contains Permethrin which is just another insect control chemical. Both of these chemicals would work well outside your home, whereas the PestXpert is good for inside and outside.
