Grid Connect tips, tricks and help
Hi all,
I thought it may he good to have a feed where we could share any tips and tricks to do with any of the Grid Connect Range being Arlec, Deta, Verve, Orion.
I am learning from trial and error and really just accident so sharing with others and sharing back we may be able to create some good learning information for us all.
Please post below starting with what the trick is as the title then how to do so as the body of information.
Carl
- Labels:
Lighting and Electrical
Re: Grid Connect - Externally triggered camera recording
Hi @EmJr,
Many thanks for your patience.
Your automation can be achieved with plug cameras only not the battery-operated ones. For outdoor, the Orion Grid Connect Smart 3MP Outdoor Pan and Tilt Security Camera would be suitable as it has the record switch option.
Thank you for tracking down the info.
A difference between mains and battery powered firmware makes sense (but it does put a crimp on my plans).
Re: Grid Connect tips, tricks and help
Afternoon all. First up - a quick call out to the folks that have driven this thread. It is a fantastic repository for folks like me who are just setting out on their home automation journey.
I am after a set of Grid Connect, solar powered, fairy lights for Christmas decorations (decorating a couple of trees, etc.). I can see the Arlec Smart 800 LED Bud Lights Grid Connect Wi-Fi Controlled Indoor Outdoor Deco - which looked promising, but they low voltage (with a transformer).
Anyone came across anything of interest?
Edited to add: Also - anyone came across an RF transmitter compatible with Grid Connect? Seen this one on eBay - Arlec WiFi RF Transmitter Self Learning Grid Connect Universal Remote Controller - just wondering if anyone has any experience of it (it appears to have poor reviews). Note - doesn't seem to be currently available at Bunnings.
Thanks in advance for any advice shared.
Hello @stevesmith2107
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about smart solar fairy lights.
I'm sorry but the store does not currently stock smart solar fairy lights or an Arlec RF transmitter. However, I can suggest a way to protect your Arlec Smart 800 LED Bud Lights With Grid Connect. To protect the transformer and plug of the extension cord, I suggest using Arlec IP44 Outdoor Safety Box. I own one of these and often use it whenever I use my pressure washer. I know that my cable is safe, and the connections will not get wet even if accidentally drenched.
To protect the electrical cable itself you can cover it with Builders Edge 1000mm Cable Protector. The cable protectors can be locked together, and you can use duct tape to keep the cable in the channel. As long as the cable protector is facing right side up it will protect the cable.
Let me call on our experienced member @CSParnell for their recommendation.
I have not been into Bunnings this year with the new Xmas light range though I do remember some being Grig Connect in previous years but they may have been hardwired. I think the issue with solar Grid Connect lights will be they won't have the ability to maintain their connection for 2 reasons 1. People will put them to far away from wifi range and 2. They constant draining of power in the system could loose the settings even if a small PCB battery was installed.
That being said nothing a 1.2ah 12v battery, 10-20w solar panel, 20w solar regulator and 12v smart outdoor fairy lights could fix if you wanted to go DIY all placed in an IP rated enclosure.
As for a RF/Wifi push button... Search Tuya push button, you will find many options and Tuya works on Grid Connect platform and vice versa, Tuya is the parent device manufacturer. Just look out between wifi, ZigBee, Bluetooth for Wifi all you need is your router, for ZigBee and Bluetooth you need a separate hub. There is also Z Wave that needs a hub.
Hope that helps
Is this the sort of Grid Connect remote control you are after?
If so, please refer to Page 12 of this Forum: "4 Gang Smart Switch Review".
I've been using one of these with Grid Connect daily for almost 1 year now. Easy to use/program and very reliable!
NOTE: The only catch is that it requires a ZigBee hub, but that works seamlessly with Grid Connect for all your Grid Connect Scenes & Automations.
Each button has ‘single click’, ‘double click’ and ‘long press’ modes to facilitate control of up to 12 devices.
(I looks like an 'Infrared remote' but it isn't.)
@GreenHouse yep that's the type I was thinking of or these are good too for ZigBee the 3 position touch ones. No not the skull haha
Help with Grid Connect Camera
Hi all,
This is a last ditch attempt to sort out why I cannot get an Orion Grid Connect Camera to pair.
I have numerous Grid Connect devices. I have never had any issue getting any of them to pair.
That is until I bought an Orion SC002HA Pan and Tilt security Camera. I follow the instructions exactly and it refuses to pair. Gets up to scanning the QR code and then it times out and never completes the pairing process. I must have tried 20 times. Eventually I decided the camera must be faulty and returned it to Bunnings and got a replacement. Unfortunately the replacement behaved exactly the same. I then contacted Arlec support and they sent me yet another camera. But it does exactly the same thing!!!
I can see that the camera is being given an address by the router.
I have had a lot of experience with Grid Connect devices and have never had a problem before and I have now run out of ideas.
The only unusual thing about my situation is we have NBN satellite internet. But why would this be a problem when dozens of other smart devices pair with no issue?
Has anyone out there had a similar experience?
Thanks in advance,
Ian
Hi @w0mbat,
Sorry to hear about the ongoing trouble you're having with the Orion Grid Connect Camera. That must be incredibly frustrating.
Have you been back in touch with Arlec support since receiving the replacement unit and experiencing the same issue? It sounds like they sent you the new unit assuming the original might have been faulty, but now that you’re seeing the same behaviour, it seems to rule out a defective unit and instead points towards something related to the Wi-Fi or internet connection.
If you haven’t already, it might be worth reaching out to them again to let them know the issue persists despite the replacement. Now that it’s clear the camera itself isn’t at fault, they may have further troubleshooting steps specific to your setup or NBN satellite connection.
@w0mbat @MitchellMc @ I would place my bets on you have either 5G or a 5G/2.4G service WiFi that you are using to try to connect to and giving the only thing the has changed is the internet service the modem probably changed but the SSID got brought across so that you didn't have to connect your other devices????? Maybe????
Given so that can you create a mobile hotspot on your mobile that is 2.4G only? The setting is usually available in the hotspot area. Set your SSID and Password.
Grab another phone or mobile device with Grid Connect or Smart Life and connect to the Hot Spot, the. Jump into Grid Connect or Smart Life and put the camera into pair mode and try to add it. See if that works. If that is a success then you know it is a 2.4G/5G issue.
Unpair the device and delete the data then tun off the Hotspot.
Next if 5G is causing the issue you have 2 options if you home wifi is running at 2 bands then turn off 5G temporary so 2.4G is just active. Put the camera into pair mode and pair again. With your mobile device.
If successful then you can turn back on your 5G band.
If you want uninterrupted 2.4G then create a Guest network of 2.4G only and pair all your smart devices to that band, make sure your main band is still dual 2.4G/5G this allows you to control your devices on the main band even though they are on the Guest Band but any time you want to add a device make sure your mobile device is connected to the guest band.
This is how my house is set up with minimal issues.
Let me know.
Subject | Author | Posted | |
July 2021 | |||
January 2023 | |||
May 2022 | |||
March 2022 | |||
October 2021 |
