Floating shelves
mazasonic
Floating shelves
Wanted to make our study room just like the below with floating shelves and table but no idea where to start. Never done any DIY before so an advice or tips are really appreciated. Could I buy these from bunnings? I had a look before and the one I'm seeing are all quite short.
Re: Floating Shelves
Here's some inspiration for you @mazasonic. I'll also tag the members as they might want to give you some tips about how to get started on your project.
Floating shelf by @Starkers_17
D.I.Y. floating shelves by @Tara86
Floating desk by @ProjectPete
Hope that helps kick things off...
Brad
I can find the light duty brackets at the big green shed.
https://www.bunnings.com.au/carinya-100-x-76-x-20mm-adjustable-floating-brackets_p3961804
Still classed as light duty but will hold 22kg
https://www.carbatec.com.au/rockler-i-semble-light-duty-blind-shelf-support
Will hold 55kg
https://www.carbatec.com.au/rockler-i-semble-heavy-duty-blind-shelf-support
They are all similar to fit with the eception of the strongest holding one that takes an extra hole in the wall.
If you have a stud wall you need to be able to find the studs to fix the brackets.
You need to cut a rebate in the back of the shelf so the bracket is hidden and the shelf sits flush.
Getting the 2 holes drilled square for the support rods is critical to get a good result, for me that would be using my drill press.
Short video to show how easy it is for an expert to do...
Jules1
Thank you for this video it is exactly what I want in my study and I am also a first timer.
Great to have you join the community @Jules1. Glad you found Brad's post helpful. Please feel free to post anytime you need a hand with this project, or any others to come in the future. We have loads of members sharing helpful advice and inspiration every day.
Welcome to Workshop,
@mazasonic
we sell a huge amount of Floating shelving, and they are probably the most simple shelving to install, go in and have a look at the range, they can be fitted to all types of materials with ease and look great
mazasonic
Wow! This is a great video. Thanks for sharing. :smile:
Any recommendations on the type of wood to get or what to considers?
I recently did some alcove shelves. I just used https://www.bunnings.com.au/specrite-1800-x-405-x-18mm-hevea-finger-jointed-panel_p8330180
Did a glued mitre down the log side and attached to 40 x 18 pine. The underside was filled with thin plywood.
58788782939__701BD1A8-62A6-4EDD-97C4-64CF03081445.JPG                              RGhztQ1XQv6fXdA2BABocA.jpg
Fantastic result @MikeyAllcock. Many thanks for sharing. Great to have you join the community and make your first post. We are looking forward to seeing more of your handiwork soon. Please post anytime you need a hand or have something to share.
