Do I need an 18 Guage or 16 Guage brad nailer?
HumzaB
Hey Everyone, I hope you are all doing good!
I need a nail gun for a variety of projects, from woodworking furniture projects to building a pantry under my stairs and slightly re-building said stairs, it is to be used in a lot of different projects but I only have enough money for one of them.
It should be noted that this is regarding the Ryobi brand Brad nailers.
The 16 gauge is R16GN18
The 18 gauge is R18GN18
Which one should I get?
Re: Hey everyone, Do I need an 18 Guage or 16 Guage brad nailer?
Hi @HumzaB,
The Ryobi 18V ONE+ 16GA Brad Nailer uses thicker 16-gauge nails, making it ideal for attaching larger trim, baseboards, and cabinetry where a strong hold is needed. It drives nails between 19mm and 65mm in length, leaving slightly larger nail holes than an 18-gauge nailer. This tool is suitable for finish work that will be painted or filled.
The Ryobi 18V ONE+ 18GA Brad Nailer uses thinner 18-gauge nails and is perfect for lighter trim, delicate mouldings, and small woodworking projects where smaller nail holes are preferred. This nailer drives nails between 16mm and 50mm, making it ideal for finer finish work. Its smaller nails help avoid splitting and leave less noticeable holes.
In contrast, a framing nailer, like this Ryobi One+ 18V Li-Ion Cordless Nail Gun is built for heavy-duty structural work like framing walls or building decks. It uses much thicker nails, typically 10- to 12-gauge, ranging from 50mm to 90mm in length. This tool is not suited for finish work, as it leaves large nail holes designed for strength rather than aesthetics.
Of the three options I've mentioned, my suggestion would be the R16GN18 as it fires slightly heavier nails while still being able to do finish work at a reasonably high standard.
