We wanted to add a pocket door to our home; we recently added an extension, where we added the bedrooms. We wanted to design a door to create some privacy so we could close the bedrooms off if we wanted to entertain.
We knew a 3m high custom door was way out of the budget so we decided to build it ourselves.
Video here - https://www.instagram.com/reel/C4qvrywSl06/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
We built the door using leftover hoop pine flooring and VJ panes. Derek constructed a frame using ripped-down hoop pine flooring and nailed it together.
We framed in the opening, taking it as wide and high as possible and in one side of the pocket door.
The hardware was installed and we hung the door.
We framed in the remaining side sheeted and painted.
Happy DIYing
Claire
Materials
Hello @Renowayoflife
Thank you so much for sharing your door assembly process. The door looks fantastic, and it would probably have cost you an arm and a leg to have this made. It's great that you had some left-over materials to build it, what is the overall thickness of the door?
Again, thanks for sharing this fantastic project.
Hi @EricL Thank you so much, love how it turned out and loving the savings you're right it would have cost a fortune.
The door is 40mm thick.
Afternoon @Renowayoflife
Now that is a brilliant idea! First up I really like the seperation if needed and then such an imposing door but hidden Nice work and definently outside the box thinking. Think I will file this away for possible future use
Thanks @Dave-1 It's great as it retracts entirely into the wall so most people don't know it's there
We have 3 small kids so it's great if you're up early you don't wake everyone up.
Hi @Renowayoflife I absolutely love this door - so impressive! Would you be able to provide a list of tools needed to construct the door. I'm sure there are plenty of members who would love to have a go at this if they have the right tools available. Such a great looking feature.
Hi @RobP
We didn't need a lot of tools for this project, we used;
Thanks Claire
