My mantra is - never throw out anything. There is always a project around the corner and in my experience, as soon as you throw it out, you will need it.
With the rising costs, we're embarking on a mission to create a homemade Christmas this year. Our goal? To infuse a homemade touch into all our gifts this season, and who better to start with than our kids?
For the past 2 years, most of their toys were stashed away in storage, and while we continue to renovate our home, our 3 kids have found joy in the small things. The house has been in a constant state of change and disorganisation so we really wanted to prioritise their playroom.
They have a wonderful imagination, and we wanted to foster this with a little dress-up zone. I have so many fond memories of my sister and I dressing up and creating ‘shows’ for my parents, Aunts and Uncles and I’m so excited to see what the kids come up with in their new space.
I went with a relatively simple design. We have a number of dresses and outfits that will need a hanging space and I wanted to have a box as the base for stability and extra storage. We had a load of plywood left from other projects so decided to make it from this and add a dowel.
I used a large set square to measure the plywood and draw the outline of the dress up box.
Happy DIYing
Claire
Materials
Tools
Cut the Ply wood
I used a circular saw and table saw. Any saw you have would work, depending on your design, this is what we had available.
Pre-drill
Once the sides were cut I predrilled a hole at the top where the dowel will be installed.
Sanding
Before assembling the dress-up box I sanded each of the pieces with an orbital sander.
Nail Gun
To assemble the dress-up box I ran wood glue along each side and nailed the joints in place.
Dowell
Once the box and sides were assemble I screwed the dowel to each side, adding the screw through the pre drilled hole.
Paint
I primed and painted the box. I had left over paint from our pantry project which was a perfect match for this project.
Nice one Claire (@Renowayoflife) many thanks for sharing.
We've had a couple of similar projects from other community members you might like to check out:
Hi @Renowayoflife Nice project and material re purposing
Hay I noticed with your wood cutting I try to adjust saw blade so 5 mm aprox only of saw blade coming through material. I was using a triton table saw with a powerfull saw spinning 9 1/2 " blade and it had the blade coming through timber panel 30 mm and the material jambed side ways a slight amount and the saw blade and it shot back at me very fast and dangerously I thought my wrist was broken Yes a rookie mistake I am sharing in case others reading can by pass my mistake.
I second that although there’s a couple of features of @Renowayoflife ’s saw has that reduce kickback.
For starters there’s the riving knife holding the blade guards down.
There’s also what appears to be blade guard like arms at the back which would hold the board down a bit as well. I’ve never seen this before but I’m liking. Is that aftermarket or does it come with the saw.
Of course no safety feature is worth its salt if the the problem exists between keyboard and chair so to speak. 😂
