prettyliving
DIY frost window film
We recently installed window film to the front doors of our new home. We had great results installing mirrored window film at our last place a couple of years ago, but this time we wanted privacy for both day & night so we went with the pillar products plain frost.
MATERIALS used (everything from Bunnings):
• Glass cleaner
• Window microfibre cloth
• Pillar Products “plain frost” window film
• Tape measure
• Scissors (to cut film to size)
• window film solution
• Applicator Set (scraper & knife)
• Ruler
PROCESS:
1. Clean windows thoroughly
2. Measure width and length of the window.
3. Cut your window film to be a couple cm larger than the window
4. Spray window film solution to the window
5. Peel a little backing off starting from the top end of the film
6. Place film onto the window, starting at the top
7. Smooth out the film using the window film applicator (scraper). Peel the rest of the backing off as you work your way down
8. Using a ruler as a straight edge guide, cut the excess film with a blade/knife. Leave a couple mm gap between the edge of the film and the window frame to allow the window film solution to run out.
9. Use the window film applicator again to scrape any excess solution out towards the edges
10. Soak up all with a cloth.
This project was quite simple to do. The trick is to take your time and make sure the windows are really clean prior to applying the film. The slightest bit of dirt will make the surface rough and will often lead to an uneven finish & trapped air bubbles.
The frosted film has made a huge difference, these windows can no longer be seen through during both the day & night so we were very happy with the result.
Remarka6le
Re: DIY Frost Window Film
Well done @prettyliving , we've used the Crystal, Frosted and Mirrored varients in our home and love all of them (the mirrored removed so much heat from the front of our home (morning sun facing), we also found the film is fantastic for when the glass is broken, as it holds together shards quite well (our dog Luna has ran through the window twice). I'm sure the frosted will give you a lot of privacy :smile:
Remarka6le
Thank you @Remarka6le
It’s a brilliant product, and super affordable! That’s a great point about it keeping the glass together! Hopefully Luna doesn’t run through yours again 😅
Great project, many thanks for sharing Jess (@prettyliving). I'm sure plenty of community members will take advice and inspiration from your post.
Akanksha
Retired Team Member
Retired Team Member
Re: DIY frost window film
An effective and simple way to add privacy to your home. Great job, Jess (@prettyliving).
A special thanks for including a step-by-step breakdown of this project and the tools and materials needed. I'm sure this information will come in handy for anyone attempting to do something similar.
Can't wait to see what project you tackle next!
Thanks again,
Akanksha
Love your work Jess (@prettyliving)! I'm now looking at my windows, thinking to myself they could do with some frosting.
Many thanks for sharing such clear instructions.
prettyliving
Thank you Jason 😊 @Jason
Thank you Akanksha! @Akanksha
It really is a lot easier than it looks, I hope the steps help to inspire others to give it a go. 😊
Thank you @MitchellMc 😊
