Electricity is confusing!!
I have this power supply that came with a security camera. I think I understand enough that it's compatible with our electrical system with a standard USA to Australia travel power point adapter (but I'm not positive). However, I'd rather purchase a replacement power supply that fits our Australian outlets.
Can anyone advise if there is the relevant replacement at Bunnings, and if it needs a power conversion?
Power adapter
The sticker on the power supply states
Input(Л): 100-240V~ 50/60Hz 0.3A
Output(輸出):12V=1A
The end that connects to the device
Is this called a DC cable?
A link to the right product/s would be deeply appreciated.
Thank you for your help!
Hey @learningDIYer ,
Good question, welcome to the community.
It's a DC adapter, yes. Takes 240v AC in and converts it to DC obvioiusly.
I'd get one of these. Antsig adapter , I've found them very useful replacements, I always have a spare, so that anything that needs whatever variety of output works.
Thank you so much for prompt advice. So the one you linked is the correct one - 9-24 VDC? I did spot those Antsig adapters and thought I was on the right track, but then saw they had a range of options all mentioning different voltages and panicked 😄
You just need to buy adapters that converts this straight plugs to the curved Australian ones. I have several adapters like this from my phones shavers etc and they all work fine
Thank you but I don't want to use an adapter as it has to fit into a tight spot.
When buying a PSU (Power Supply Unit) you have to be careful as there are regulated and unregulated versions. Regulated means a device in the PSU holds the output stable at the listed voltage. unregulated PSUs can vary in voltage depending on the load. In your circumstance, I would recommend finding a regulated one
Hey @learningDIYer absolutely.
the one I linked allows you to select the output voltage, basically with a flat head screwdriver to turn the yello selector switch, which is then hidden when it's plugged in.
I've used them heaps of time.
Thank you so much!
Thank you I didn’t know that. I can’t see that detail in the Bunnings listings or some other local retailer items, including the one specifically linked by Walter. If they are regulated, will it state so?
Hi @learningDIYer,
Let me tag @CSParnell, but I believe the unit @Walter has suggested would be suitable.
