So back in 2013 I had my new house painted. The guy who painted was a "professional" (hardly) and he said he had sealed the walls which he obviously didnt as you can see by the photos, 90% of my walls i can just peel huge chunks of paint off.
So ive been scrapping and peeling back to the bare walls (I live in Perth so the walls are brick with plaster set over top)and then applying a skim coat on the places my scrapper has taken bits of plaster away.
So once the bits of skim coat plaster has been sanded back smooth, whats a good sealer primer to use?
I really wanted to use oil based but i have indoor animals that ive read it can be harmful for them to breath in, plus oil based takes longer to dry and dont want my animals hair getting stuck on the walls while it dries. So i guess water based is what i need to use, but which one? Any info would be appreciated
Hi
This solution may raise some eye brows but it is perfectly sound in application.
Wet down your very porous plaster with a mixture 1 Part PVA Glue with 3 parts water and let it dry Use brush and or roller.
Wont cost you the earth in expensive under coats.
Hello @jordcam1983
I propose using Dulux 1Step Prep Primer, Sealer & Undercoat 4L. My best advice is to make sure that all the dust on the surface of your walls have been wiped away before you coat it with the primer.
Thank you. Ill be wiping it down for sure. Ill use my vacuum with a brush attachment and wipe down the excess
Hi @jordcam1983
I have used a very similar mixture before binding a dusty cement and brick wall ready for rendering. My actual water mixture was bond crete which is very similar to PVA and it really works well sealing waterproofing and providing a good under base for additional top coatings to stick too.
Sounds like your plaster could use a little binding and the pvc coating allows paint to bind to it more easily but lets prove it to our selfves before you do your whole house you dont need another coating failure I have being there too.
I highly suggest we do a test of the mixture I am sure you might have Aquadere in your shed or some can be bought in small bottle, mix some with water and try in on a test area inside a cupboard then paint it.
I was just doing some economics and Shelleys Aquadhere PVA is $21.95 for 500ml Mixing this into the water ratio will give us 2 litres only.
So there is no gaining economically using this PVA solution and @EricL paint choice is the better paint choice with out the oil paint smell or science project to test it
I want you to use a sure thing you dont need this task again any time soon.
The walls under the paint are quite dusty from removing the high quality paint🤣
