Adjusting gutter slope
LouK
Hi Everyone.  I need to adjust my gutters to get the correct fall towards downpipe ect.  How do i go about it??
Ive attached a photo of my gutters and brackets.  Any advice much appreciated.
Re: Adjusting gutter slope
@LouK,
Welcome to Workshop. We're pleased you could join us and trust that you'll be inspired by our community member projects and also receive plenty of helpful advice and information.
I'm sure members will be able to provide advice to improve your guttering. I take it water is currently pooling at the moment? Let me tag former plumber @LePallet for you, he might like to kick off the replies.
Thanks again,
LePallet
Hi @LouK
How much of the gutter are you wanting fall
unfortunately You May to or get a roof plumber to take the gutter that is needed off and hopefully adjust it enough with out  taking to Much off
or another option is add another down pipe in the area where is affected
LouK
We have been working on adding downpipes to eliminate problems.
But 18 metres full length, side of the house runs well apart from the last 1.5 metre forcing it back and to pool in the middle and overflow when raining.
Every corner would hurt to be adjusted to as far as we can see.
I was hoping to be able to do it ourselves by somehow adjusting those brackets. But i cannot find any videos or info on it.
LePallet
Yeah I can see what you mean. The only way of adjusting those brackets is taking the gutter out and lifting the bottom of the sheets to re adjust each bracket
Good luck
zallum
Hi, i have the same problem and was wondering if you found a fix please?
Hi @zallum,
Welcome to the Workshop community and thanks for joining in the discussion. Let me tag @LouK for you so they are alerted to your question about how they tackled this issue. Unfortunately @LePallet mentioned above that the only options are to remove the guttering to adjust the fall or add a new downpipe where the water is pooling.
thanks, was just curious to see if thats what they chose do do :smile:
