Adding a flyscreen to my awning
Ammy
Hey there please advise me How to install aluminium frame flyscreen to my A&L awning  window how can I level from bottom part of window to attach aluminium frame on it  thanks 2B222161-5BAB-4CF0-BEC2-CE51C8CBB9F6.jpeg
Re: Adding a flyscreen to my awning
Hi @Ammy,
You'll find constructing fly screen for this type of window slightly more difficult than a standard window. You will need to work around the winding mechanism as the bottom ledge is not flat. If you were to fit a standard screen, there would be a gap on the side of the winding mechanism. At my property, someone has pop-rivetted a Metal Mate 20 x 12 x 1.4mm 1m Aluminium Unequal Angle to the bottom of the screen and cut out around the winder to fill the gap. I've included an illustration below of how that would work.
You should find this step-by-step tutorial helpful: How to replace a flyscreen by @Tara86.
Please let me know if you need further help or had any questions.
