Hi I am looking for instructions to make a wooden pool pump cover. Can you help?
Community manager's note: Check out How to build a pool pump cover for expert advice.
Welcome to the Bunnings Workshop community @lethal78. It's sensational to have you join us, and many thanks for your question about the pool cover project.
I've sent that copy through to your email. Let me know if you need any assistance with the build.
Hey @MitchellMc , could you please send me the plans so my son and I can give this project a go. I've read the plans but work better off a hard copy.
Welcome to the Bunnings Workshop community @OldMan72. It's fantastic to have you join us, and many thanks for your question about this project.
I've sent a copy of the project through to your email.
Any suggestions on best way to cover and protect the pool pump from the harsh Perth 🌞 , which is only for a small concrete pool.
Hello @OldMan72
You might find it helpful to check out the "How to Build a Pool Pump Cover" guide, as it provides a good overview of constructing a cover using a timber frame and Merbau panels. The cover can be secured to either the wall or the floor with angle brackets for added stability. The process starts with measuring the pump and its fittings to ensure a proper fit before assembling a simple timber frame around it. Once the frame is built, Merbau panels can be cut to size and attached using hinges. This design allows the panels to be moved aside when needed, giving you full access to the pump, including the back, for easy maintenance.
