paining over spray
rhodes
paining over spray
What is the best spraycan primer to use to paint over silicone? My exterior board and batten cladding needs a repaint, and there are areas where silicone has been used, around cable entries etc….
cheers,
Re: paining over spray
Hi @rhodes,
Typically, paint or primers won't adhere well to silicone. This is why silicone is often coloured and is applied after painting.
If it is an exterior gap filler as opposed to silicone, then it can be painted without any issues, but if it is silicone then paint will not stick to it regardless of whether you use a primer or not.
Exterior paint such as Dulux Weathershield, Taubmans Sunproof and British Paints 4 Seasons are self-priming, so there is no real need for a primer if you are using an exterior paint such as these.
