building a mudpit in soil
Kathy88
Hey,
I want to build a mudpit (no too muddy) in the backyard. I want it to be levelled with the soil and will put large rocks around the boarder. As the mudpit will be level, what type of sleepers or other non toxic material should I use for it? Haven't completed decided on the size but will be around 2mx1.5m.
I have some aqua boxes I bought intending to create a waterfall but don't think I will. Could I use those for underneath for drainage or it's not necessary?
For the mud inside, I will need to use clean soil. I read loam is a bit less messy than other soil. I this true for Sydney weather? Do I fill the whole 2x1.5 with Loam? Any recommendations for brands I can use?
Re: building a sandpit in soil
Hi @Kathy88,
Building a mud pit in your backyard sounds like a fun project Since you want it level with the soil and bordered with large rocks, it's important to choose materials that are durable and safe for outdoor use. For the border, timber sleepers that are treated with ACQ instead of CCA are a great option. You could also use natural stone or composite sleepers, which are both sturdy and long-lasting. Just ensure that whatever material you choose is free from toxins, especially since you’ll be dealing with soil that could be in contact with children or pets.
Regarding drainage, I'm not familiar with what aqua boxes are, so if you could provide further information, that could assist me in answering your question about them. If you’re in an area that experiences heavy rain or your pit needs to drain excess moisture, some form of drainage should be considered.
For the mud inside, clean loam is a great choice for a less messy, smoother texture. Loam holds moisture better than sandy soils, making it less likely to dry out and create dust. It’s also better at providing a consistent texture for mud play. Since Sydney can be hot and dry at times, loam is ideal, as it retains water while still draining well. As for filling the entire 2x1.5m area, it really depends on how deep you want your mud pit. If you're aiming for a good depth, you could go with a mix of loam and some sand for added texture and drainage. You might like to speak with our team in-store at the Special Order desk to see if we could order you some bulk loam.
Could I ask what this mud pit is for as I'm sure our members will be interested.
Kathy88
Thank you for your reply. I want the mudpit for my toddler to play in. I'll be adding a mud kitchen and a play table.
I've added a pic of the aqua block but I think it's a bit excessive for a sandpit.
Thank you. I will definitely ask the front desk about the bulk loam.
I'm a bit worried about mosquitos and other bugs. We also have a stray cat strolling around at times. Does anyone have ideas of what to add to the soil to repell bugs and the cat pooping in it? Was thinking adding bulk salt and eucalyptus oil or something. Has anyone experimented with this?
Evening @Kathy88
I think your project spunds pretty interesting, I remember playing in my sandpits (mudpits) and I was happy as a pig in mud especially when I was allowed to use the hose and make dams! The dirt piles were either a trailer load of soil in the corner of the yard or I was allowed to play in just an old raised garden bed (that was better as it kept my water for dams in it easier)
As to the question of keeping cats away I would suggest a tarp that you peg down when the pit isnt being used. Maybe even have the tarp on a roll (around a brrom handle say) so you can roll it up while the mudpit is being used? :smile: Cats love sandpits so something that dosnt let liquid through is what I would suggest. I would also suggest a light rake that you use once you lift the tarp, something that you do as a reflex to make sure nothing has crawled under the tarp overnight.
Would love to see a pic of the mudpit once done btw
Hi @Kathy88,
I'd agree with @Dave-1 that a physical cover would be the best way to deter cats. Or you could use a cat-repellant spray. The cover will likely help avoid some bugs.
The Aquablock does look a bit excessive for a mud pit.
