Hi everyone, just about to try replacing a long ( 27.2 x 2.4) deck using Ekodeck. Can anyone tell me if the 6mm plastic clip system is easier/ better than the 3mm metal clip system.
I prefer the look of the 3mm gap but all the installation videos mostly show the plastic system.
Hi @cathie12
Thanks for sharing your question about the clipping system for Ekodeck. They actually have a page that fully explains the difference of the clipping systems. To summarize the difference, using the 6mm plastic clip allows you to lift a single panel out of the run if you need to access the bottom of the deck at a certain spot.
The 3mm metal clip is not as forgiving and you will need to disassemble the deck panels in order to get to the spot you need to reach. The spacing is merely a design feature according to Ekodeck, but I believe that the 6mm spacing allows for better air circulation under the deck.
Thanks Eric,
Have ordered the 6mm after watching countless videos both appear to have merit but the deciding factor was easy removal of a single board if needed down the track.
Boards are being delivered today so we will soon know if we made the correct decision.
Thanks for your advice.
Keep us updated on your project @cathie12, as we can't wait to see your results. Please don't hesitate to reach out again if you need further assistance.
Hi there, I'm about to try and make the same decision, 3mm vs 6mm... how did yours turn out? Would you still pick the 6mm?
Welcome to the Bunnings Workshop community @ravenmands. It's sensational to have you join us, and many thanks for your question about Ekodeck.
Let me tag @cathie12 so they are alerted to your question, and hopefully, they can provide some feedback on their experience.
We look forward to hearing all about your projects and plans around the house and garden. Feel free to reach out anytime you need assistance or have something to share with the community.
