What power tool to drive in fence U-nails?
BoeingFan
Becoming a Leader
Hi everyone. I'm about to replace a fence that the fires destroyed a couple of years go, but now I need a fence around a quarter acre block to keep my sausage dogs secure, I'll be using the Longyard wire mesh, with square timber posts initially. I have not built a fence before, and was thinking I'd use U-nails to fix the wire to the timber posts: https://www.bunnings.com.au/paslode-40-x-4mm-500g-galvanised-staple-nails-45-pack_p2360440
I am going to get into the Ryobi One+ ecosystem, and I'm unsure if there is a suitable power tool to drive these U-nails? If there is, could someone please tell me what is it called?
Cheers!
Re: What power tool to drive in fence U-nails?
Hi @BoeingFan,
I'm unaware of any cordless tool that will drive those staple nails; they're a hammer-in type of fixing. We can order a wire stapler, but the staples are very fine and unsuitable for fencing. Also, these staplers are typically air driven, so you'd need a compressor close by.
Remember to have your posts on the other side of the fence to your dogs. You should only need to place a staple at the top and bottom and a couple in the middle. Are you planning on running a guide wire and tension strainers, as these will increase the rigidity of your fence and minimise the number of staples you'll need?
