Trailer Cover
muzza_niko
Trailer Cover
How & what can I cover our high caged trailer with, we tried tarps, ratchets & tie downs, tarp rips. Every time we take it off, to put large items in trailer. Must be removable roof. Costs us alot, everytime we use trailer.
Currently we have a double bed frame on roof with no cover.
We would like recommendation, trailer companies claim short staff & pandemic issues.
Re: Trailer Cover
Hello @muzza_niko
Welcome to the Bunnings Workshop community. Thank you for joining us and sharing your question about your trailer cover.
I recommend a change of material to canvas for example Heavy Duty Canvas Tarp Tarpaulin 8' x 10' 16oz Waterproof Green. You can also use heavy-duty vinyl tarps available online. Regular tarps are not strong enough to withstand strong winds when running on the motorway.
Let me tag our experienced members @tom_builds and TedBear for their recommendations.
tom_builds
Making a Splash
Re: Trailer Cover
Hi @muzza_niko welcome to the Workshop community,
Canvas is probably the way forward as @EricL has suggested. As for having a cover that is easy to take on and off with a removable roof, you're best option would be a customer cover with zipped sides. If trailer companies are giving you the run around, you could try going direct to a canvas producer and they may be able to produce something for you.
If that's not an option, I would look at using a system where three sides of the trailer are always covered in a canvas cover, with two separate canvas covers for the rear and the roof that can be removed when the trailer is being filled and then replaced. This will save you from having to unwrap the whole trailer everytime you want to use it.
Keep us updated with your project progress, and best of luck!
Re: Trailer Cover
Thinking about buying this
https://www.bunnings.com.au/wagner-3-65-x-5-48m-heavy-duty-canvas-drop-sheet_p1663203
& tieing it up with
This
 https://www.bunnings.com.au/grunt-6mm-x-30m-reflective-rope_p4310562
Cheaper & stronger then our usual tarps we use, what do use think, will it hold all weather conditions.
Re: Trailer Cover
Hello @muzza_niko
Thank you for giving us an update on your search for a good trailer cover.
The Wagner 3.65 x 5.48m Heavy Duty Canvas Drop Sheet is an excellent cover sheet for inside residential use only. I'm sorry but it has no UV or weather-resistant features that will make it last out in the open. This product has a plastic membrane sewn into the back of the canvas to provide superior shielding against paint spills and stains. It will not last against harsh wind and weather.
I strongly recommend exploring the option of getting a custom-made cover for your trailer. It may be more than you wish to spend, but it is a worthwhile investment. The benefits of strength, toughness, and the ability to withstand harsh wind and weather are all in that one cover.
Please keep us updated, we look forward to seeing your trailer covered and secure from the weather.
muzza_niko
Re: Trailer Cover
Re: Trailer Cover
Hi @muzza_niko
The Polytuf 3.6 x 5.5m Heavy Duty Tarpaulin looks promising. However, you may run into the same issues as mentioned before. It is rated for outside use but strong wind, while the trailer is moving, may tear it apart. If you were to use it only as a cover when at home then it should work. But if you use it while it is moving, the Tarpaulin will not last.
muzza_niko
Re: Trailer Cover
muzza_niko
Re: Trailer Cover
Finish project until a local Trailer Warehouse contacts me, to modify Caged Trailer to Box Trailer, with removable roof, if not high roof.
Re: Trailer Cover
Hi @muzza_niko
Thank you for the update. That should keep your trailer protected in the meantime. We look forward to seeing the trailer once it has been modified.
Please keep us updated.
