Timber deck in backyard
RS
Hello folks, I've no prior experience in timber diy projects. I want to build a 4 by 8 metre deck flushing with the grass on a slightly sloped backyard. How should I prepare the ground so that there are no issues with drainage, pests, snakes etc?
I think I should do this:
1. Lay a weed mat directly on the fresh top soil
2. Build the base frame of deck with support posts into the soil about 30cm deep, screwed to the Base.
3. Fill the base completely with some gravel.
5. Install top layers.
Not sure about the type of timber, screws, etc.
Please help.
Re: Timber deck in backyard
Welcome to the Bunnings Workshop community @RS. Many thanks for your question, I'd be happy to assist.
One of our fantastic members @Adam_W has just posted a comprehensive article on How to build a low-level deck which I would encourage you to read through. You can certainly lay gravel down to aid drainage and Adam_W goes into some detail about how to do this in his article.
I've put together a basic plan of the deck structure for you to work with. The bearers I've used are Treated Pine Outdoor Timber Framing 190 x 45mm and the joists are Treated Pine Outdoor Timber Framing 90 x 45mm. You'll need to contact your local council to check regulations, specification and whether a permit is required.
Here's a helpful step-by-step D.I.Y. article on How to build a timber deck which I trust you'll also find useful in the planning and building process.
Please let me know if you need further information or have any questions
RS
Thanks very much. I'll go through the article and get back if I have questions.
RS
@MitchellMc  Hey mate, are you able to help me with cost estimation of this plan against any unit of measure such as per sqm? I've done mine per sqm but just not sure if this is correct or not
Hi @RS,
I've had a look myself at those figures and my cost estimation is very similar to yours. Please bear in mind this is just a rough estimation and doesn't necessarily translate well into the real world. You'll need to take into account stock availability of the timber you need and over length wastage on each piece of timber. It does, however, give you something to work with.
Please let me know if need further information or had any questions.
