Should I clean the fence before painting?
annatr
Hi there,
I'm starting a new project to improve the shady area along the side of our house.  I'm particularly keen to improve the view from the laundry (picture below) and would like to go all out on this small section of the fence by installing a lovely vertical garden....
My first step is going to be to paint the whole fence along the side border of our property (around 30 metres) a charcoal colour.
This product looks to be what I might need...
https://www.bunnings.com.au/walpamur-10l-charcoal-fence-finish_p0018737
However, the fence is looking a bit green in places (see the next two pictures), so I'm not sure if I can paint directly onto the fence, or if I should give it some kind of treatment first... I'd be really grateful for any advice...
With thanks,
Anna
Re: Fence treatment for shady side lane
I'd certainly recommend that you remove that growth before painting @annatr.
Do you have a pressure washer? One would be an effective way of removing the growth from the fence. Alternatively, you can use 30 Seconds 5L Outdoor Cleaner With Power Sprayer and a stiff bristle brush.
Here's a helpful video on preparing and coating an exterior fence. If you can manage within your budget, I'd suggest going for premium paint like Dulux Weathershield. You'll find the coverage and quality to be much better.
What type of vertical planters were you thinking of using?
annatr
That's all super helpful - thank you @MitchellMc
I'm not completely decided about my vertical garden solution.  Top of my list of possibilities is the Wallgarden vertical garden system. Some friends of ours have the modular multi-hang vertical garden kit and it looks fabulous.
Wallgarden recommend mounting to 50x50 mesh, so I was thinking of mounting sheets of this mesh https://www.bunnings.com.au/rapidmesh-600-x-1200mm-50-x-50mm-silver-wire-mesh-panel_p0087119 directly against the cross beams of the old fence.  I guess I can just put in some wood screws and use something like this https://www.bunnings.com.au/whites-mesh-panel-fix-clip-50-pack_p3060012 to get them nice and stable....
Does that all sound reasonable to you?
Warm regards,
Anna
That sounds like it would work a treat @annatr.
I've installed some of these Holman Vertical GreenWall Garden Kits into a large 4 x 1.2m wall. They have a fantastic, fully integrated watering system. Each kit you attach is joined together and irrigated simultaneously. They can all be run off a single tap timer. I've included a picture below of one I did for my local Bunnings store entrance. It's much fuller now and really looks impressive.
annatr
That looks fabulous - thanks again for the advice @MitchellMc
