Hi all, I am using a drill driver on lowest torque and speed setting to drive screws to assemble a BBQ. However, I have stripped two screw holes threads despite of being very careful and not exerting much force when driving. Screw holes are steel as is the BBQ, What else I could be doing wrong and what other steps should I take not to strip any more screw holes.
Morning @foxhound
One thought is to ditch the driver - just use a humble hand-held screwdriver so you can 'feel' the tension building - then once this is achieved - stop.
Can you please upload photos of the stripped areas? I'm sure we can offer fixing solutions.
Cheers.
That's quite unusual, @foxhound. A drill driver on its lowest torque setting should barely be able to drive a screw in, let alone strip a screw hole. Typically, you'd put the torque setting on mid-power and not have any issues with stripping. Even on the highest torque setting, it would be unusual to strip a screw unless you were being careless.
It sounds like something else is going on here. As mentioned, you could use a hand-held screwdriver, or if we can see the type of screws and the damage that has been done, that might provide more information.
