Outdoor bathroom with solid rock floor
finished floor in outdoor bathroom
when making an outdoor bathroom floor out of rock seamed like a good idea
Started to cart in the rocks and place in a crusher grit base while trying to keep it flat
all rocks in place and held there with crusher grit, it was then hosed in for a few days to help it settle
next step was to dig out some of the crusher grit down about 80mm ready for the motar grout
made a strong mortar grout using sand cement and bondcrete scooping it in and filling all the joints
once it dried out enough we hand washed it to get excess motor off the rocks with a water and acid solution
Re: Outdoor bathroom with solid rock floor
Another impressive project on a significant scale @matweb. Well done.
When you say "seemed like a good idea" - I take it you wouldn't do it again or recommend others tackle it? Certainly all your hard work looks like it was worth it from here!
Thanks for sharing.
It was definitely worth while, but the rocks were extremely heavy and took some lifting, I had to first get them on the back of my ute one at a time could only put about 8 or 10 on at a time as they are quite large some ar 30-40cm long and 20cm round. Maybe if anyone would like to attempt something similar I would suggest maybe sourcing a cut version if that is possible
Huge undertaking, looks fabulous, you should be very proud of what you've done.
I laid some standard bricks in my garden as an edging to mow up to and it was hard enough to make sure they were level and they're not uneven like rocks!!
Well done and welcome to the community workshop community, I'm sure you will love and and learn allot as well as impart allot of knowledge too.
Barbara
Thank you for you kind comment.
Subject | Author | Posted | |
November 2022 | |||
February 2024 | |||
March | |||
November | |||
March |
