Oil or stain recommendation for my deck
vg_39
Cultivating a Following
Hi guys,
I have been sanding my deck and fence around the deck for last few days and it has turned out to be nice so far. I am attaching the photos of before and after sanding.
I am at a stage to clean the deck and then oil/ stain it. Considering this is my first diy, I am considering using intergrain product as I have read it’s easy and long lasting.please correct me if there are better products in market that I should look into.
I am seeking guidance on below:-
1) Which product of intergrain should I use on my deck. I would prefer a product which helps me not to sand my deck again as it’s too hard. Also, I want lower maintainence.
2) colour options of oil or stain. I am currently considering between Merabu and Walnut for deck and some darker shade for the fence (Perhaps Jarrah for fence).I have read that the colours on old decks can be inconsistent with what’s shown on the label of these products. I would prefer a colour which works on the older wood deck as per the pics below.
The deck is old, close to swimming pool and I don’t exactly know the wood type. All I know is that the deck was built 30 years ago. Looking at the colour of the wood, it’s perhaps cedar or treated pine.
Thank you for your time and I will keep posting the progress of the deck
Before sanding deck above
Before sanding the fence above
After sanding fence
 deck after sanding above
zoom in on deck after sanding 
Re: Oil or stain recommendation for my deck
Hello @vg_39
Welcome to the Bunnings Workshop community. It's awesome to have you join us, and thank you for sharing your question about staining your deck.
There are quite a few choices when it comes to oiling and staining your deck. But before you make your choice, I suggest cleaning your deck with Intergrain 1L UltraPrep Timber Cleaner to revive your timber deck and remove the grey tone that's currently on your decking panels. Integrain oil comes in different stains they are Natural, Jarrah, Merbau and Spotted Gum.
Because your deck is natural timber any product you put on it will eventually fade and deteriorate. It will be necessary to update and maintain the finish of your deck. I recommend visiting your local store and going to the deck sample finish board in the paint department so that you can actually see what the oil stains look like. Please keep in mind that due to the age of your timber deck, some stains and oils could come out darker.
Once you've made your choice, I suggest testing a small corner of your deck and letting it dry off so that you can see if you like the finish. If it is agreeable you can then commit the entire deck.
Here is a link to our best advice: What decking oil do you recommend?
vg_39
Thanks Eric for the post
i eventually went with merabu and my deck now looks like this with two coats.
On a seperate note, for the gate, I used cetol hlse mahagony.  
Well done @vg_39, many thanks for coming back and sharing your results.
Let us know if you need a hand for the next project.
