New gable roof over front verandah
Materials
Tools
All timber structural members with corrugated steel roof sheeting and flashings to match the existing house. Internal lining is marine grade plywood. All fixings were either stainless steel or galvanised. All major materials purchased from Bunnings.
Makita sliding compound mitre saw, Ryobi cordless drill & driver, Makita circular saw, Bosch jigsaw, Ryobi multi-tool, Makita router, Ozito cement mixer & hand tools, all purchased from Bunnings
Steps
Step 1
1/1
1. Lifted existing roof sheets to bolt in 5 steel brackets to support rear truss.
2. Fabricated rear truss & bolted into place
3. Dug footings for front posts & installed soil anchors and poured concrete (bags & cement mixer).
4. Installed timber posts and fabricated front truss in-place
5. Installed all timber purlins and noggings to link the two trusses.
6. Installed gutter, roof insulation and corrugated roof sheeting & flashings
7.Installed front weatherboards and barge boards
8.Installed internal stained & varnished marine-ply ceiling paneling
9.Installed internal front gable lining using painted marine ply
10 Installed low-voltage internal RGB LED lighting system with remote control
Re: Gable Roof
Welcome to the Bunnings Workshop community @GerryH. It's wonderful to have you join us, and many thanks for sharing your project.
What an awesome addition. You've certainly made a dramatic improvement to the space. Do you have any before images? I trust our members would love to see the finish you achieved on the ply ceiling boards. It's a question we have come up quite often.
Thanks again for sharing, and well done.
Re: Gable Roof
Hi Mitchell,
Thanks for the reply. I have attached a before photo, one during the build and a couple of the completed inside showing the marine plywood ceiling. Also, a photo of the LED lighting.
I spent a lot of time researching how to finish the marine ply because it had to match other ceilings in the house. In the end, I opted for Intergrain Ultradeck Timber Stain in Redwood and finished it off with Cabot's Clear Deck & Exterior Stain in a satin gloss. A chap at Intergrain gave me the procedure because plywood is not easy to stain and finish. The procedure, after sanding, was to vacuum the surface and wipe down with metho' on a clean sponge and leave to dry. After applying the stain (1 or 2 coats depending on the plywood colour), allow to dry for 3 days before overcoating with 3 coats of the clear finish.
Regards, Gerry20220319_172924_2.jpg 20230331_142004_2.jpg 20240410_111633_2.jpg 20240410_111644_2.jpg Busselton Gable roof LED Lights.jpg
Re: Gable Roof
Hi @GerryH
Thanks for sharing the extra photos of your gable roof. The addition is just amazing and the finish on your marine plywood is just outstanding. When combined with the LED lights it makes the mood very adjustable. It's perfect for any occasion you can think of.
Many thanks for sharing.
