I haven't had a vegie/herb garden for a long time. I just missed having having fresh herbs and vegies.
had some pallet timber that were in my shed, I got these from a pallet manufacturer, in my area about two to three years ago, they were very fresh and wet, then, now they have completely dried out and good to use for my project.
Trolley size, 110cm long x 54cm wide x 90cm overall height
Pallet timber (free) for the planting boxes.
Merbau timber 70mm x 19mm, (pre oiled).
4 Castor wheels - 2 Braked and 2 Non braked.
Screws for mounting wheels
Wood Glue (Wellbond) for the pallet timber.
Polyurethane glue for the pre oiled merbau.
Screws for assembly.
Weedmat material for inside of boxes to protect the wooden boxes
Fixing clips for weed mat.
Router table for cutting box joints on pallet timber
Router for biscuit joining merbau timber.
Drill for assembly.
Mitre saw.
Various clamps.
Pallet box size,520mm x 540mm x 200mm
Cut pallet wood to suit boxes.
Using router table, cut out the box joints.
Glue and clamp boxes.
Cut to size the base timber for each box, leaving gaps for drainage.
Cut the merbau timber for the trolley
Cut out biscuit joints.
Clamp all timber using polyurethane glue, I found that the wood glue wasn't suitable due to the pre oiled timber.
Install castors.
Cut and fit weed mat into boxes.
Paint trolley and and boxes with decking oil.
Fill planters with potting mixture.
Plant seedlings and seeds, then wait for the magic to happen and follow the sun.
Hi @Tyro @I haven’t thought of , so far no problem, not required.
good luck with you future projects
I was a fitter a long time ago.
you can read my story on the Bunnings Workshop
Well @JoeAzza I think you and everyone else who can make their own tools are very clever indeed! Full marks for figuring out how to do something like that! I think it puts each of you in 'Star' status! 👏👏👏
Again I send out a massive thank you to you, @JoeAzza !
I didn't even know of the existence of Wellbond adhesive (Bunnings I/N 1210590)! It works miracles! An absolute must-have for any woodworkers!
Cheers 🤗 🤸
