Low level deck next to a pool
alexanderCa
Hi all, these forums have been very helpful in planning my poolside deck. I have a few questions from the experts which I havn't been able to find yet though before I submit my plans.
I am planning on building a deck alongside this pool.
The ground slopes gradually away towards the pool filter, so I originally planned a combination of bearers on stirrups and posts on stirrups. After consulting span tables I have landed on 175*75mm F14 bearers and 100*50mm F14 joists. Plan to use SS joist hangers and screws. Noggins arent on the plans, but will incorporate.
Here are my plans so far:
Screenshot 2025-02-14 163542.pngScreenshot 2025-02-14 163528.pngScreenshot 2025-02-14 163502.pngScreenshot 2025-02-14 163356.png
Here are my main questions:
**Does anyone see anything obviously incorrect about this design? I have consulted the forums and Allan Staines' manual and will use for fixings and joints. There are no site drainage issues, just pool water splashing.
**I would have prefered to use stainless steel post supports given deck is poolside. 75mm isnt available, so that would involve levelling the ground to allow enough room for a stirrup and post on the high side. Is that worth it, it will mean the site doesn't drain as freely as currently. Is Gal sufficient? It is a mineral rather than salt pool.
**Am I overthinking this and should I just mount H4/H5 posts into the ground and be done with it?
**What life expectancy am I gaining by using stirrups and hardwood rather than posts in the ground and potentially pine bearers and joists?
**I was planning on joining the bearers with a half lap joint and a nail plate on the side. I assume the best place for this is above the post, but this will block a nail plate on one side. Should the join be somewhere else?
Thanks all for you help in advance
Re: Low level deck next to a pool
Hi @alexanderCa,
You've already got a nice solid plan in place; however, you should check the allowable spans for the joists as the span tables I've found show 100x50 F14 Hardwood is not capable of spanning 2 metres between bearers. You will need to size up to 125x50mm F14 Hardwood, which is capable of spanning 2.3 metres between bearers.
Stainless steel hardware should definitely be used where possible as it is much better at resisting the corrosive effects that are present around pools. You can always use a larger stirrup such as this VUEPRO 300 X 90mm Stainless Steel Full Stirrup Post Support and add packers inside the stirrup before bolting it in place.
I couldn't tell you an exact figure for how much life expectancy you are gaining, but stainless steel is the most durable material in an application such as this, so it is worthwhile using it.
I prefer keeping the in-ground contact of timber and concrete to a minimum, but if you'd be more comfortable using an H4/H5 post, it would be worthwhile coating it in a bitumen membrane to help prevent decay from the wet conditions.
Your half-lap joins should be located directly over a stirrup. Using a stainless-steel nail plate alongside screws through the top and bottom of the joint will create a nice solid connection. If you are using a 90mm stirrup, then there will be plenty of clearance for this nail plate.
All in all, you have a solid plan that I'm excited to see come to life.
Allow me to tag @Dave-1, @TedBear and @Nailbag to see if they have any thoughts.
Hi @alexanderCa
Super impressive set of plans there. @JacobZ  has covered off all your questions just as impressively. The only thing I would add is the use of Protecadeck strips on the joists. And to consider by sub-floor stage and requirements for running low voltage lighting cable. A very long time ago when I had a pool with a surrounding deck I built, I also added tubes to drop in umbrellas for both deck seating or pool edge shade for the kids.
Thanks Jacob. I must be misinterpreting this table. I will up the joist size. I have decided to move to 90mm posts which will work with the strirrups you have linked and dig out the depth as required.
Thanks, good tip. I was also planning on painting the stirrups and bearers with outdoor paint as they will not be able to be seen anyway.
Evening @alexanderCa
Nice plans :smile: And @JacobZ and yourself have already sorted the only thing I saw an issue with (the span between posts)
I have stirrups for my poolside deck and they are on slopped ground. They are gal and go into the ground 600mm ish
Pool deck stage 1 is the project. Its still standing solid as after 11 odd years :smile: Just did a bit of maintenece on it this last year (sanding/oiling and re-oiling)
I like @Nailbag's suggestion of the low voltage lighting, id also up the anyi and consider a power point somewhere (away from the pool ) You probarly have an outside powerpoint/gpo for the pump so it may be easier then you expect to put another one in for parties ect.
Looking forward to seeing the deck :smile:
Hi @alexanderCa,
The information I could find on spans for F17 Hardwood was very limited and you're interpreting your span tables correctly, so it is likely fine to use seasoned 100x50 F17 hardwood for your joists.
If you wanted to be absolutely certain your deck was strong, then it would be worthwhile bumping up the size of the joists, but based on your span tables, it is likely not necessary.
I'm very excited to see your project get under way, so please keep us in the loop as things commence.
Both good ideas. Did you mount tubes on the joists or set in a footer?
