Low-level deck between brick walls
aaron11
Having an Impact
Deck build went great!
  • 250-400mm high (ground is on a slope)
  • Size is 4600 x 2270mm
  • Earth underneath
  • both 4600mm sides are concrete/brick walls
Dynabolted ledgers onto either wall. Used brackets bolted into pre-existing pavers to support the posts down the centre. New 120mm merbau for the trims, reclaimed merbau for the main deck space. Steps took a bit of figuring but turned out great.
Re: Low-level deck between brick walls
Love your work @aaron11, thanks again for sharing.
What do you think were the most important lessons you learned during the project that might assist others tackling decking projects down the track?
Love your work, @aaron11! That reclaimed timber is just sensational. I'm really pleased this project worked out well for you, and good luck in the competition!
Sam01
Great effort . It may be important to seek Council approval when constructing deckings if next to the property boundary as in the case of this project. There is the Overlooking consideration into neighbour's property that could impact what height from ground level is allowed and necessary mitigations.
Many thanks for joining in the discussion @Sam01. It sounds like you have plenty of knowledge and experience to share with the community. We are looking forward to reading more of your posts soon. Please don't hesitate to post whenever you have something to share or need a hand with your own project.
Welcome,
Morrning @aaron11
That looks great! Have to say anytime someone reuses resources is a win and catches my etyes straight away!
You said the steps took a little to work out? How so? I am about to have a go at putting in some temorary ones and was wondering what type of issues or knowledge I would need.
Would love to step through those doors out onto that deck frist thing in the morniong :smile: Of course with a cup of coffee as the roofing add shows us :smile:
Beautiful job
