Hi All!
Currently own a Ozito 1800W 2030PSI High Pressure Washer. There is a need to clean the roof and was looking for a Telescoping Pressure Washer Wand to reach the heights.
Any chance someone recommend a product that fit the Ozito brand?
I checked their website but couldn’t find a lengthy wand sort of item to do the work.
Thanks in advance!
Hello @AGM
Thanks for sharing your question about an Ozito telescopic pressure washer wand. Although the Ozito pressure washer comes with a host of accessories, I'm afraid there is no telescopic wand that you can use to wash your roof.
However, I don't recommend using a pressure washer on your roof unless you're a roofing specialist or have experience with roof maintenance. Poor assessment or incorrect diagnosis of the current condition of your roof could result in damaged/split tiles or create leaks.
Instead, I propose using a long wide head scrub brush and a liberal application of 30 Seconds 5L Roof Treatment Concentrate. It can be used on a variety of roof surfaces including clay tile, concrete tile, colour steel, super 6, slate, synthetic tiles, polycarbonates.
Please remember to wear personal protection such as gloves, goggles and a mask when working on your project. If you decide to work on your roof, remember to take all safety precautions such as using a safety harness.
Thank you very much! appreciated. Can you please advice on how to spray this to the roof without a telescopic sprayer or something? I have a steep ( would say 45 degree roof) so standing in roof is not at all possible.
Appreciate your thoughts. @EricL
Hello @AGM
In this particular instance, I suggest engaging the services of a professional roof cleaner. The majority of the telescopic sprayers with tanks available are not long enough to reach past 2 meters. This might not be enough to reach the top of your roof. Having a professional clean your roof will save you time as they will have the equipment to reach high areas.
