How to treat cracked Merbau decking?
David10
Hi Community,
We've just had our deck redone and we've noticed a lot of cracks in the merbau where the screws are. Our carpenter has completed about 95% of the screws and there are about 100 cracked areas on our 60m2 deck. He's been using these screws, which do not require a pilot hole, as long as you're far enough away from the edge and ends of the boards, I believe:
  • Simpson Strong-Tie 12G (5.5mm) x 65mm 316 Stainless Steel DHSD No-PreDrill Hardwood To Softwood Decking Screws
He's advised us that he hasn't been drilling pilot holes when in the middle of the boards, but has been on the ends of the boards with a regular drill bit the same size as the screws, but not a countersinking drill bit.
The decking is pre-oiled 90x19mm merbau.
He will likely replace the worst of the boards, but with about 100 cracks, we won't be able to get everything.
Reaching out to see if there's anything we can do with the cracked boards that are left. Currently planning to wash, oil and maintain regularly, but also considering trying to seal cracks with Selleys Aquadhere PVA Wood Glue Exterior Adhesive, removing adjacent screws, wedging boards closed, re drilling screw holes and then screwing again. To try to seal up the cracks as much as possible.
Any advice would be greatly appreciated.
We understand that predrilling all screws with a countersinking drill bit 15-25mm from the edges and ends of the boards is best practice and how to avoid this happening, but the deck is almost finished now and we're looking for a solution moving forward.
The wedges in the photos are marking some of the cracked areas.
David
462585862_9030083257036781_3438325756224859162_n.jpg 462572685_1207557640315151_8024031039533632475_n.jpg 462549138_1520421988556540_1073367049452497400_n.jpg 462587249_541200855390355_249690966778981774_n.jpg 462584151_926991525694744_5747308257239032589_n.jpg 462569482_1357553678556414_3472282748184049616_n.jpg 467474723_1959813761164578_5433839327705350683_n.jpg 467482406_1310147967002531_2061104778900494628_n.jpg 467472754_448313111640574_5672820655250264018_n.jpg 462570140_534406792905410_8602238199938034146_n.jpg 462582754_1841852832886644_2545528986845889045_n.jpg 462567450_1711137409463200_8112402221414829257_n.jpg 467474288_1953196761815790_7690427949369350413_n.jpg 462567022_904326755139941_3623503450368603778_n.jpg 462574726_1307084606966802_7021212208182767346_n.jpg 462575404_2056447554758247_498888566459386449_n.jpg
David10
Re: Merbau decking issues
Hi @JacobZ,
Thanks very much for contacting Simpson.
The majority of the cracks are at screws that are closer than 20mm from the edge, however quite a few are at 20mm. I've attached a few more photos.
Could the timber being very dry cause this? It was installed a few days after delivery.
David
462567472_948771400505125_7259180660828493120_n.jpg 467330057_1079393890594923_8384793396741153912_n.jpg 467331081_1129932707991025_238803432323103943_n.jpg 467370276_3573546096276577_3366043818867300005_n.jpg 467424755_928287522599310_3895625688393757882_n.jpg 467474351_2305798386455674_7891896185552387229_n.jpg 467488083_2483758038490227_8051132718925873545_n.jpg
Hi @David10,
Yes, dry timber will lose some of its flexibility and is likely a contributing factor to the cracking.
Ultimately, a combination of things will have caused the cracks and if the installer were to do it again, they should predrill all the boards to ensure it doesn't happen again.
David10
Hi @JacobZ,
It looks like pre-drilling with a countersink has taken care of most of the cracking, but our carpenter has had a look and was frustrated as at least one board has cracked, even with pre-drilling. So it seems like some cracking may be unavoidable? Or maybe too high setting on his impact driver could contribute? The board seems like it might crack easily as there's a crack in the second photo that's not even at the screw.
Are cracks like these normal or acceptable in a new merbau deck? Mostly keen to understand what's normal and what we should be telling our carpenter.
David
462579153_2811837832357056_2553069949599718592_n.jpg 466964195_380589258476350_2986510080236581951_n.jpg
Afternoon @David10
In all the times I have used merbau decking it has split on my twice, and thats because I was going to close to the edge on purpose (was making a bracket edge) and overtightened after the predrill.
Courtyard privacy fence and gate build, Part 2  Step 4 fourth photo up on the handrail is the split I caused. It was because I was predrilling the 19mm width to go into the flat handrail and I didnt have my drill absolutly vertical 😕
Were they new boards that cracked? If so then possibly the torque/impact driver was too high. I have used Merbau that has sat in the garage for 6 months waiting to be used and there was no issue. I use a torqued driver not an impact drill. Impact drill, I have issues with screws shearing off when I go into hardwood posts through hardwood decking.
Hi @David10,
If your carpenter is predrilling and countersinking the screws, regardless of how dry the timber is, they should not split unless the screws are being overdriven.
Predrilling and countersinking will remove material so there is a clear passage for the screw to go through. The only way splitting will occur is if the screw is overdriven causing the timber to compress which will push sideways to find space and potentially crack down the line of the grain. The screw should be driven until it just applies pressure to the top of the board.
My impact driver, which I always use to install screws, has multiple power settings and when installing screws that had the potential to split things, I would always put it on the lowest power setting and take care not to overdrive the screw. This is not too much to ask of your carpenter when installing screws close to the end of the boards.
