How to replace tempered glass for Marquee outdoor table?
peterclarkryan
Can I purchase a replacement glass top for my Marquee 7 piece Steel sling back Outdoor setting ( Model number 3191814)?
My existing table worked well for about 10 years before disintegrating last week
Jewelleryrescue
Re: How to replace tempered glass for Marquee outdoor table?
Hi @peterclarkryan
Tempered  glass is hard to make and refit for your table even at glazieres
Can I  suggest  switching to polycarbonate , perspex  or lexan table top you can buy sheets  cut to size with 10mm  thickness approx you can cut it with angle grinder metal  cutting blade melts its way through  (jigsaw will work but may chip edges.)
Take table to plastic  supplier they can measure cut it for you and recommend thickness.
Oh it if scratches polish it out with brasso   but try use table  covers to reduce  scratches.
Welcome to the Bunnings Workshop community @peterclarkryan. It's terrific to have you join us, and many thanks for your question about replacing a glass tabletop.
Unfortunately, replacement glass tops are not available for that product. I suspect, given the Marquee 7 Piece Steel Sling Back Outdoor Setting is a budget-friendly option, if Marquee were to provide a replacement glass panel, it would come close to the price of the full setting. Is rust developing on the chairs at all? If so, my advice would be to consider purchasing a new setting, as you'll likely find that the next thing you'd need to replace are the chairs.
