How to replace part of an old fence?
totocol
Building a Reputation
Hi community,
I’m planning to replace a section of an old fence where the wood is rotten and slowly get the full fence replaced. I’m planning to start with about 7metres and these are the materials I thought I’d use. Just wondering if I might be missing anything. I’m also getting someone to let me use their nail gun and circular saw.
Rails x 3
https://www.bunnings.com.au/100-x-15mm-1-5m-fence-paling-h3-treated-pine-wet_p0051200?referrer=Retai...
Palings X 75
Galvanised bolts x 5
https://www.bunnings.com.au/zenith-m12-x-220mm-hot-dipped-galvanised-hex-head-bolt-and-nut_p2449137
Nails X 300
thanks!
Re: How to replace part of an old fence?
Hi @totocol,
The pailings and bolts are fine to use, but I'd be keen to see what you're using the bolt for. Typically there are no bolts in a timber fence construction.
You've double-linked the pailing there; could you give the rails link another go? Also, what are you using for the posts?
In case you haven't seen it, here's a helpful step-by-step guide: How to build a pailing fence.
totocol
I’m adding photos of the fence. The idea is to replace the palings and railing and the wood in planning to use for the railing. The bolts are to at each the railing to the concrete posts
Hello @totocol
Thanks for that extra information about the concrete posts. I was also wondering what the nut and bolt were for. My only suggestion to your new fence upgrade is to add a timber capping over your fence. The capping will serve as a defence for the top of the paling and prevent water from sitting on its cut end.
It looks like you've got all the parts you need. I only suggest double checking the size of the current raling. It's best to use the same size so that you won't get any bowing in the fence. Please don't forget to post photos while you are dis-assembling and re-assembling the fence. I'm sure our members would be keen to see the process.
Please remember to wear personal protection such as gloves, and goggles while working on your fence.
totocol
Thanks @EricL
I couldn’t find an exact match for the railing size but the one I posted is pretty close so hoping it’s close enough. Just a couple of final questions
Is there a particular wood I should use for the capping?
should I add any additional treatment to the palings and rails after installing them?
thanks again!
Hi @totocol
The caping is actually paling cut in half right down the middle. To protect any cut portion, I suggest using TWA Woodcare 300g Ecoseal Tanalised Timber Treatment
Please make sure to wear personal protection such as gloves goggles and an appropriate mask or face shield. Please make sure to follow the safety recommendations at the back of the can before using the product.
totocol
Thanks a lot.
one final question. I don’t have a nail gun but I do have an impact driver. What screws would you recommend for this job?
thanks!
Hi @totocol,
Climacoat 45mm Treated Pine screws would be about right.
