How to replace Marquee bistro blind?
SandyKP
Hello,
I have a marquee bistro blind that was installed 2.5 yrs ago.  It's 140 x 210.  It needs replacing and I cannot source that size anymore at Bunnings Armidale.  Is it possible to source a replacement elsewhere?  Thanks Sandy
Re: marquee blind
Hello @SandyKP
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your marquee blind.
I've had a thorough look and could only find the Bistro Blinds 150 x 240cm 0.75mm Clear With Black Trim PVC Outdoor Bistro Blind and the Bistro Blinds 120 x 240cm 0.75mm Clear With Black Trim PVC Outdoor Bistro Blind. You are correct that the 1400mm x 2100mm is no longer available. One way to address the size difference is to use the Bistro Blinds 120 x 240cm and adding Bistro Blinds 10 x 240cm Clear Outdoor Bistro Blind Zip Joiner on both sides to give you back the 1400mm size you're after. I'm currently not aware of another source for bistro blinds.
