How to remove water stain on garden bed concrete blocks?
Rhyan
Hi guys,
I need some help and advice how to clean/remove the water stain marks on my garden bed concrete blocks? Also how to prevent this to happen again? Do I need to paint it or apply any water proofing paint?
Appreciate your help.
Jewelleryrescue
Re: How to remove the water stain mark on my garden bed concrete blocks
Hi @Rhyan
I have a wall  i want to keep clean too from whipper snipper grass stains and other dirt splashing up.
Well to partially clean (As it is already stained) it a high pressure washer is the strongest solution. Next apply aa clear sealer.
 A concrete block wall could use a heavy-duty sealer
This will help repel further stains
An additional  idea is to add low garden edging strip    (many  types avaliable.)to ward of grass cutting mess etc,
Hope this helps
Welcome to the Bunnings Workshop community @Rhyan. It's brilliant to have you join us, and many thanks for your question about sealing blocks.
To tackle the water stains on your garden bed concrete blocks, it’s important to first understand where the moisture is coming from. If the water is coming from outside, applying a clear sealer to the blocks would likely help prevent further staining. This would block the absorption of water and help protect the surface of the blocks. A concrete sealer such as Dulux 4L Clear Matt Concrete And Paving Protective Sealer should be suitable.
However, if the water is coming from inside the garden bed, such as moisture seeping out through the bottom, the solution becomes a bit more complicated. You may need to remove the soil to access the inside of the blocks and apply a sealant to the wall to prevent moisture from leaking out. It’s important to note that sealing the wall on the inside might not entirely solve the issue if moisture is wicking up from the lower blocks, which could still lead to staining.
