I’m not too sure how rain is coming through under the door but when there is heavy rain I noticed a lot of water coming through under the front door. What can I do to fix this? The raven weatherstrip installed as per pic has a gap underneath which I can see sunlight coming in from the inside, could it be that it’s not installed low enough? What else can I do to stop this from happening?
Hi @homefix,
Welcome to the Bunnings Workshop community, it's great to have you with us.
I believe you're correct that it has been installed too high. If installed correctly, when closed, you should not be able to see a gap underneath the weather seal. The solution to this is likely as simple as moving the weather seal down so that when the door is closed, the rubber strip has solid contact with the tiles underneath.
Can you advise if this is an adhesive backed seal or a screw fixed seal? This will have some effect on the method of reinstalling.
Let me know,
thank you for your reply, it is screwed on however I just noticed that the cam lock (not sure what it’s called) the rubber that locks it when door is closed is not installed. Can these be purchased seperatrly
and are they easy to do?
Hi @homefix,
Looking at the Raven 920mm Clear Anodised RP3 Door Bottom Seal, you are correct that there is a part missing.
I would head to the Special Orders desk at your local store and show them the above. They can get in touch with the supplier and order the spare parts for you.
