How to pave over a old garden bed?
Simeon1
Hi Team,
I would love assistance please with understanding what I need to do to fill in this gap with pavers to suit existing? We previously had an old brick planter box there which I have removed.
The idea is to just use brick pavers to hopefully make it look like a continuation of the existing.
I would also love advice on how to smooth over the wall so I can paint it etc.
Additional info;
- Air-con unit you can see in the image will soon be relocated away from this location.
- Unsure at this stage what the white pipe in the photo is and can image it will be the main challenge?
Thanks,
Simeon
Re: How to pave over a old garden bed?
Hello @Simeon1
Thanks for sharing your question about paving over an old garden bed. You're correct, the main challenge will be that white PVC pipe as it will be in path of the pavers. I suggest engaging the services of a licensed plumber and asking them if it can be diverted or eliminated altogether. Once that pipe is out of the way there should be no issue with laying down new pavers. I don't recommend cutting the pipe yourself as it might be connected to your current plumbing.
In regards to the walls smoothness, I suggest sanding it down first to give you a better idea of what section needs filling. If that section is lower than the existing wall, I suggest using Dunlop 4L Premix Render Joint And Patch. Please make sure that the wall is clean and free of debris before you start patching.
Simeon1
Hi @EricL ,
Pipe is now removed and able to pave over this area.
Can you please share some tips and a guide on steps to pave this area? My calculations is that this area needs approx. 21-25 of this paver (https://www.bunnings.com.au/brighton-masonry-200-x-100-x-40mm-sand-mypave-paver_p3451992).
-Is there a recommended pattern between staggered running bond or herringbone?
-What is the best way to break/cut bricks accurately and easily without an electric saw etc.?
-The area does get some water flowing across it so what should I do to ensure it doesn't get washed out etc.?
Thanks,
Simeon
Hi @Simeon1
You could use a staggered running bond to fill that gap, my advice is to think about the pattern that will blend in with your existing pavers. Using a herringbone pattern is nice, but it will stand out and make that repaired section noticeable. To cut the pavers, I suggest using a grinder with a masonry rated diamond blade. You can also use a brickies bolster, but you'll need a bit of experience using it as it can accidentally break the paver at the wrong angle. To make sure that water does not settle on your freshly paved section, please make sure that your foundation has a fall integrated into it. this will make the paving surface self-draining.
Here is a handy step-by-step guide: How To Pave A Pathway.
Please remember to wear personal protection such as gloves, goggles and a mask when working on your project.
