We recently had a ramp removed from the side of the house and it’s left a bit of a mess! I’m hoping there is something I can patch the holes with before bagging over all the bricks to tidy it all up?
Any suggestions of products to use would be great please!
Thank you!
Hello @el1
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about patching your brickwork.
I suggest using either a Dingo 10KG Structural Mortar Repair Bag or Sika 20kg Sika MonoTop-352NFG Structural Repair Mortar. These mortar products can be built up to fill in gaps and holes in your brick wall. It will have a flat finish on its surface, but you can create brick lines using a Kango 10mm/13mm Brick Jointer, but you'll need to have a steady hand to make sure it lines up with the rest of the bricks. You also have the choice of leaving it flat and just bagging the bricks.
