Hi, I have a side gate where the latch doesn't reach the strike plate. Easiest fix seems to be to add something behind the hinges to move the gate over slightly. Only needs about 1cm. Plate measures approx 4 x 10.5cm. What would be the best product for this? I only have limited tools at home so ideally not too much cutting etc. Thanks!
Hi @jibs2,
I'd suggest using some window packers to pack out behind the hinges. You can then just screw straight through them back into the existing holes.
Let me know what you think.
