How to match mortar?
Alex100
Hi all!
I'm looking to match the mortar in an old house and need some advice, please!
I have a reasonably large amount of repointing to do in a 1910 house. Water has unfortunately started coming through to damage interior walls and need to fix outside to start.
It's quite a light, sandy and soft compound (hoping for something a bit hardier).
Also trying to avoid last owners mistakes 😬
 Cheers, Alex!
Re: How to match mortar?
Hello @Alex100
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your brick mortar.
If this is very old mortar we're looking at odds are it has been bleached by time and the weather so it's no longer its original colour. If you look at your third photo, there was an attempt to repoint the bricks with standard mortar. You can clearly see the colour difference between the old and the new.
It is technically possible to lighten the tone of the standard grey mortar by adding Dulux Avista Oxide 1kg White Cement Colouring. But it will be nowhere near the finish of the old mortar. There is also the option of using Easy Mix 20kg White M4 Mortar and making its colour darker by adding black oxide.
Here is a handy step by-step guide: How to mix mortar
