How to make a slope for Pergola roof?
michaelsync
I have a Pargolas similiar to this.
I want to put a roof on it.
Do you recommand to use the flat roof https://www.bunnings.com.au/sunlite-10mm-twinwall-x-3-0m-clear-polycarbonate-roofing_p1010590 or this one https://www.bunnings.com.au/suntuf-trimdek-3m-solar-grey-polycarbonate-roofing-sheet_p1010785 or corrugated roof https://www.bunnings.com.au/suntuf-1800-x-660-x-16-beige-cooltop-corrugated-1800mm_p0037610 ?
The top part of my parlago are flat. I need to make a slope for the roof. I am thinking to put the Batons https://www.bunnings.com.au/42-x-42mm-5-4m-baluster-handrail-h3-pink-pine-fj-primed-losp_p0052850?pr... but they are all same size. Do I need to sand them to get different height?
Thanks.
Re: How to make a slope for Pargola roof?
Hi @michaelsync,
Adding a roof to a pergola significantly alters the structure's dynamics, and it’s important to ensure that the pergola can safely handle the additional weight and wind loads. Many prefabricated pergolas are not engineered to support roofs unless explicitly designed for that purpose. Adding a roof without verifying the structure’s capacity could compromise its integrity, especially in high winds. To ensure safety, it’s recommended to consult with a structural engineer or professional before proceeding.
If your pergola is suitable for a roof, polycarbonate sheets are an excellent choice due to their lightweight and durable properties. The Sunlite Twinwall sheets provide a modern aesthetic and good thermal insulation, but they require sturdy framing due to their flexibility. The Trimdek sheets offer a flat, sleek design that’s easy to install and provides UV protection. Alternatively, the Corrugated sheets are lightweight and effective at dispersing water, making them ideal for sloped roofs.
Using treated timber battens to create the necessary slope is a practical approach. However, instead of sanding them to different heights, consider elevating the high end to create a slope down to the low end. Ensure the slope is at least 5 degrees (a 1:12 pitch) to allow proper water runoff. For added durability, secure the battens with corrosion-resistant fixings and ensure the roof sheets are installed according to the manufacturer’s guidelines.
Thank you. Sorry. I missed the notification.
I bought the structured wood from bunnings.
Re: >> instead of sanding them to different heights, consider elevating the high end to create a slope down to the low end
I am sorry. Does it mean I lift up one side? put some wood underneath one side?
I was following this video https://youtu.be/_oK2hhzFs1E?si=CIrvjQp5KghvL5x6 but I don't really understand how she created the slope. Do you have any video or picture?
Hello @michaelsync
I watched the video twice and there was no picture of a slope in the guide. It could be included in the kit she purchased. For your project I suggest following Mitchell's advice and elevating the high end to create a slope down to the low end. Ensure the slope is at least 5 degrees (a 1:12 pitch) to allow proper water runoff.
I'm sorry but I don't have a video guide on how to make a slope for a pergola.
