How to fix cracked reticulation piping?
cyberbash
Community Newcomer
This is probably a straightforward question, so apologies but I'm new to reticulation so I'm not sure where to start.
It looks like someone has driven over a part of the reticulation and as a result there is a crack (pictured). I can see a Ratchet Clamp holding two of the pipes together but I'm not sure what the part that's actually broken is called and therefore how to replace it. The bit that is cracked seems to be attached to a circular black disc beneath it, but again I'm also not sure what that is and if that also needs to be replaced.
Re: Tips on fixing some cracked reticulation piping?...
Hello @cyberbash
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your damaged reticulation piping.
I'm going to have to ask you to dig further into the soil in order to reveal what the entire part looks like. It appears to be a standard 90-degree elbow that is on some sort of standing plate that prevents it from moving. It could also be a plug end with a footing. Either way we'll need to see the entire structure in order to tell what it is. Once you have it out of the ground, please take a photo and post it here. We can then do a search for the part that's been damaged.
cyberbash
Community Newcomer
Hi Eric, thanks for the reply and for the warm welcome. I’ve taken some more photos-it seems like the black pipe just plugs into the white pipe. The connection seems quite snug and I can’t see any fasteners so it may be glued in?
thanks again
Hi @cyberbash,
The damaged black plastic part appears to be an irrigation riser with an elbow joining it to your poly irrigation line.
The piece underground is a PVC pressure elbow which will be glued in place.
Unfortunately, you are going to have to cut it off and replace it with a new one as the irrigation riser is glued into it.
If you can advise what the diameter of the poly pipe and the PVC pipe are, I am happy to recommend a suitable replacement.
Let me know how you go.
