How to fix concrete colour after acid washing?
https://www.bunnings.com.au/bondall-5l-hydrochloric-acid_p0960235?store=6415&gad_source=1
They sell at bunnings
Re: How to fix concrete colour after acid washing?
Hi @PatDIY_Dad,
I'm not sure about that one. We can see the original lighter shade of your concrete through the comprised sections of the painted coating. You seem to have a light blue area at the bottom and a deeper blue at the top, with a transition line through the middle. You then have a much darker stain from the acid in the middle.
I can't imagine that acid would cause bare concrete to turn darker, so perhaps it was some interaction with the painted coating. If anything, it would typically lighten the colour of concrete. Acid washing the whole area might be an option, but I am concerned that it will become a big mess.
You might like to look towards a product such as Rust-Oleum 3.78L Concrete and Garage Recoat Primer for compromised painted coatings and then a compatible topcoat like Rust-Oleum 3.78L Concrete And Garage Floor Paint, essentially re-painting the whole area.
Thanks for the reply
its not painted its coloured through concrete
Might try give it a good wash first with boiling water and dishwashing soap see if that makes any difference. Probably wont though
It would be worth giving it a go @PatDIY_Dad.
The colour looks fairly inconsistent for coloured concrete. It appears that the colour is only on the high or low spots, which gave the impression of paint. See how you have light blue, darker blue and then grey? Grey would be the uncoloured concrete. Perhaps it's just the picture, though. I'll point to the grey in the image below, which is seen over your entire picture. The top right corner is a fairly solid colour, but the rest seems quite streaky.
What you are seeing it just dirt thats all
I just washed it. When it dry's ill take a another picture but from higher up so you can see the whole area
Subject | Author | Posted | |
August 2023 | |||
3 weeks ago | |||
March | |||
October | |||
March |
