How to fill large gap between window and brickwork?
BiancaR
I have just noticed a large gap between my bedroom window and the brickwork.  The gap starts at 1.5cm at the bottom and increases to about 2:5cm at the top.  Any ideas on how to fill the gap would be appreciated.
Re: How to fill large gap between window and brickwork?
Hi @markymark6,
You're correct that the majority of expanding foams in Australia are an orangey yellow colour and I'm not 100% sure why this is.
It could possibly be because they are not intended to be visible and exposed, so the manufacturers don't put a lot of thought into colouring these products.
An interesting question.
is it possible to get the expert from Bunnings to this job in my house please?  Thanks
Regards, Husam
Hi @husam,
Thank you for your post and welcome to the Bunnings Workshop community, it is fantastic to have you with us.
Unfortunately, Bunnings does not offer a sealant and caulking installation service.
If you are looking for advice on how to carry out the job yourself, I'd advise running a bead of Selleys Brick And Concrete Sealant along the line between your window frame and the bricks. You can use How To Silicone a Gap for a guide on how to apply sealants.
If you were looking for someone to carry out the job for you, I'd suggest using a service such as HiPages or True Local to find a handyman or caulking specialist that operates in your area.
