Hi guys,
Requesting for recommendations and information on the following project I am planning parallely to other.
I would like to put concrete surface ( or concrete slab), sorry if the terminology is wrong, on addition to my existing drive way.
Question : Is there particular standard (size and length) of the driveway in QLD or I can increase my existing driveway for spare car parking ?
AREA 1:
AREA 2
AREA3
AREA 4
guys, the purpose is to make the front area clean and use the unwanted area and make extra space for car parcking and what sorts of tool I will be using to do this or this is something I should leave for professional people.
I would like to chip in or do whatever I can do. I need to be carefull on pipes, exhaust, termite treatment holes (have left unused for a while, need to reset it).
Keep up the good work.
Thank you. Happy Thursday.
Hi @Sugar,
Expanding a concrete driveway for additional parking is a great way to make better use of your space, but there are a few key factors to consider before starting. In Queensland, driveway standards and regulations can vary by council, so it's best to check with your local council to confirm whether there are any restrictions on driveway extensions, including size limits, setbacks, and approvals needed.
For Area 1, removing the tree to gain extra space seems feasible, but you'll need to check whether extending the driveway to the red-marked area complies with local regulations and whether council approval is needed to remove the tree. The termite treatment area should not be covered with concrete, as it may impact future treatments. You might need to leave a gap or install access points. Additionally, if the yellow-marked area is prone to water pooling, drainage considerations will be important to prevent water from collecting under the new slab.
For Areas 2 and 3, concrete surfacing can help with weed control and improve the appearance, but before pouring concrete, you should confirm what the two visible pipes are for. If they are stormwater or sewer pipes, they may need protection or adjustments to avoid damage.
For Area 4, extending the driveway into the blue-marked section once again might require council approval, especially if it extends to the property boundary or impacts street access.
In terms of DIY feasibility, small concrete slabs can be manageable if you have experience with excavation, formwork, and pouring concrete. However, larger driveway extensions often require professional assistance to ensure proper grading, reinforcement, and drainage. You'll need tools like a concrete mixer, tamper, screed, and float, and may need to hire excavation equipment if significant digging is required. If you're unsure, consulting a concreter for at least part of the project might be a good approach.
Afternoon @Sugar
Thats a few questions to get through
Removing Australian natives - Check with your local council for the ruling, there are usually fines if the tree is removed outside allowances.
Making driveway larger over footpath area - Check with your local council over rules. I have not seen this allowed.
Driveway width - My local council has rules for driveways and widths as it impacts parking on the street ect. Theyare resonably admimant about rules so definently check the council rulings. Thye will have a link on their webpage. It may take a few pages to get to the information is all.
Covering other areas - Figure drainage and where it will flow to with a hard surface area. You may be exchanging one issue for another. Also factorin heat reflection especially being in Queensland.
Before covering the garden beds with concrete I would also suggest to get a plumber out to verify the condition of your pipes in case there is an issue so it can be rectified before the concrete goes down.
With the amount of concrete you are thinking of doing I would probarrly edge towards getting a professional company to do the job over doing it yourself. I would make sure they have a builders licence and check to make sure it is valid. I would also ask for examples of their work and go and see the people they give you.
Thank you @Dave-1 @MitchellMc
I am going to borrow your own words to answer and ask questions again.
Answer : Checked with Arborist. They said i should not have any problem, being in my area and 1.5 meters inside my area.
Answer: I liked the idea about heat in queensland. We are still going ahead mainly for the cleanliness.
For the Area 1, If not increasing the witdth of driveway. I was thinking if this can be done like following
I saw this in my neighbourhood.
Hello @Sugar
My best advice is to make sure you have it in writing. Send an email with pictures about your plans to the local inspector or council arborist explaining what you are planning to do. They should email you back with either instructions or at least an email indicating that your plans are within council rules. It's one thing when its being said verbally and another when it is an official written response. You will at least have proof should you ever get inspected and asked about the alterations.
