I'm wanting to convert an old planter box, which has limestone retaining on the leading edge to a section of seating, using decking products. Should I make use of the existing fence posts as part of the structure or build around using separate footings. Lots of base rock in the ground so some area's could be challenging to place footings. Any ideas appreciated.
Overall length is about 4.5m and average width is about 1m.
Welcome to the Bunnings Workshop community @Mark74. It's terrific to have you join us, and many thanks for your question about constructing seating.
Your fence should not solely support your seating, though it can be used as an attachment point. Whether you need to connect to it will likely be determined by the design of the seating you're going for. If you can provide our members with a sketch, that will help them suggest adequate ways to support your structure.
You can construct a frame and have the rear of it sit on pavers and adjustable pedestal feet; this is a fantastic way of achieving a stable frame over uneven terrain or where footings would be inconvenient.
If you can let me know what the seating would look like I'd be happy to create a rendering of a frame layout for you.
