How to clean deck cabling stained with decking oil?
Euroka
How do you remove Feast and Watson Deck Oil from stainless steel deck cables and shackles?
Re: How to clean deck cabling stained with decking oil?
Hi @Euroka,
Welcome to the Bunnings Worshop community, it is great to have you with us.
I would suggest soaking them in hot water with some dish soap to loosen the oil. Then, while still wet, I would use Flexovit 400 Grit Wet And Dry Sandpaper as an abrasive to remove the oil. This finer grit sandpaper, when used wet, should remove the oil without scratching up the surface underneath.
Let me know if you need further assistance.
