Hi All,
I think I have finally finished my design for my deck which will be half over concrete and half over soil.
Over the concrete I have 180mm to the top of the brick. I will be using 140x19mm merbau. For the joists I plan to use 140 x 45 Pine set 21mm off the concrete using Zinc Plated Reinforcing Angle Bracket with the joist. I will Dynabolt these using a DynaBolt Plus Hex Nut to the concrete every meter or so.
The joists have 355mm centres, I will just use a nail gun to fix these every 1m along the joists.
Over the soil, I will dig out about 300mm and put down crushed rock and ag pipe for drainage. The posts will concrete in 300mm and out 320mm. With bearers cut in. I will be using 190 x 45mm Bearers with 1218mm spacings. The posts will have 1000mm spacings.
The deck will also be a picture frame deck.
I have drawings below, please provide any comment, or issues, corrects, errors you may notice.
Perfect Thank you
Hi @JesseS6,
Yes, I would compact the road base, but I would compact it level. There's no need for a fall in the road base.
