How to build a wooden walkway 1.2m wide?
Rick3
Can I get away with two parallel 90 x 45 bearers1.2m apart(the width of the walkway) supported by short posts every meter along the length. Deck will be 90mm wide Merbau deck boards. Walkway will be only slightly above grade.
Re: wooden walkway 1.2m wide
Hi @Rick3,
480mm is fine, but the more you go over 450mm, the more bouncy the decking will be. They'll bend under the weight of a person.
Bugle screws for attaching the noggins is perfect.
You could, in effect, use posts sitting directly on top of a solid base such as a paver, so having them embedded even slightly into the ground in concrete should work.
There are no issues working with the slope. However, if it changes gradient mid-run, you might just need to pay attention in those areas in case it causes complications. I think you'll be fine, though.
Rick3
Thanks Mitchell,
You got me thinking, could I use pavers instead of posts? Even one on top of another.  I think I could make this very stable.
Rick
Could do @Rick3. Although a bit more expensive, pavers and then mini pedestal feet are a great way to get a level deck. If you take a look at this guide on How to build a deck, you'll see I used them over pavers.
Rick3
Thanks Mitchell,
My idea is the same as in your deck plan but would be actually cheaper. Lay the bearers directly on the pavers or two pavers to raise it a bit more?  The extra paver I expect to be cheaper than a tuff block. What are the concerns with this idea?
Rick
The only concern I have is that without the adjustable pedestal, you need to ensure your pavers are perfectly level @Rick3.
