Can I get away with two parallel 90 x 45 bearers1.2m apart(the width of the walkway) supported by short posts every meter along the length. Deck will be 90mm wide Merbau deck boards. Walkway will be only slightly above grade.
Hi @Rick3,
480mm is fine, but the more you go over 450mm, the more bouncy the decking will be. They'll bend under the weight of a person.
Bugle screws for attaching the noggins is perfect.
You could, in effect, use posts sitting directly on top of a solid base such as a paver, so having them embedded even slightly into the ground in concrete should work.
There are no issues working with the slope. However, if it changes gradient mid-run, you might just need to pay attention in those areas in case it causes complications. I think you'll be fine, though.
Thanks Mitchell,
You got me thinking, could I use pavers instead of posts? Even one on top of another. I think I could make this very stable.
Rick
Could do @Rick3. Although a bit more expensive, pavers and then mini pedestal feet are a great way to get a level deck. If you take a look at this guide on How to build a deck, you'll see I used them over pavers.
